Username password
stevie66
Username password
Is the username password the same password for logging into your account details, i only want to know this because i want to change my router and you have to add them details in before it can work and get online , now i have forgot my password details and lost where i wrote them down ages ago, but i do know my login password to check my account billing and perks and so on, is this the same password if not how do you change it?
4 REPLIES 4
Fixes: 388
Re: Username password
Yep, your account password is the one you use.
Fixes: 585
@stevie66 dont forget that the username must be suffixed with @plusdsl.net
stevie66
Thank you
stevie66
Nice one
