Copying settings from Hub One to Hub Two
mcintoshuk
I guessing the answer to this is "no", but is it possible to transfer settings from a Hub One to a Hub Two? I'm planning ahead for a move from FTTC to FTTP, and have a relatively complex setup of static IPs and port forwarding rules in my Hub One that I could do without having to recreate in a new router.
Tags (3)
7 REPLIES 7
Re: Copying settings from Hub One to Hub Two
You are correct, the Hub One backup can not be restored on a Hub two
Screen shots will be your friend here
Edit: Setting static IP Address on the Hub Two can be quirky
Fixes: 480
Moderator's note:
Thread moved from Full Fibre to My Router.
mcintoshuk
Thanks, that's entirely what I expected, but hope springs eternal...
Fixes: 585
Which FTTP product are you thinking of getting ?
The Hub one will work on FTTP but it has an upstream bandwidth limitation of 30Mb. So it will work fine on the FF80 or FF145 products but will limit bandwidth on the FF300 or above
mcintoshuk
No, I'm looking at the 500 offering, so I'm committed to the Hub Two, but I'm wondering if the Hub One can be configured as a bridge/range extender (for items that won't really benefit from the upstream rate, e.g. my WiFi printer, which is a pain to re-configure).
Fixes: 480
@mcintoshuk
You can’t use a Hub 1 as a wireless extender but you can configure it as a wireless access point. See
https://community.plus.net/t5/My-Router/Using-a-2nd-Plusnet-Hub1-as-a-Wireless-Access-point/m-p/1385...
mcintoshuk
A WAP would do. Thanks.
