Use a BT Hub 2, 3, 4 or 5 on a Plusnet connection
- My Router
- Use a BT Hub 2, 3, 4 or 5 on a Plusnet connection
- « Previous
- Next »
Re: Use a BT Hub 2, 3, 4 or 5 on a Plusnet connection
10-05-2018 12:54 PM
This was my issue too! glad to see a solution! Hopefully get it sorted tonight
09-06-2018 6:03 PM
I'm on Plusnet fibre FTTC , and its working great, but just for the hell of it to see it wifi would be any better, i purchased a BT Smart Hub- Type B.
Bought one off ebay, reset it, put my Plusnet details in, checked the stats page in the hub it says i am connected as i am on a static IP With Plusnet i can confirm its all ok and on my account.
But nothing in the house (pc/tablet/phones etc) will not connect to the internet, Plug my old FTTC router in and it all works ok.
Anyone any ideas what to try?
09-06-2018 11:10 PM - edited 09-06-2018 11:11 PM
Try splitting the 5GHz and 2.4GHz and logging back in to each. Perhaps you have confused them!
09-06-2018 11:32 PM
Thanks for the suggestion, but i should have mentioned it's wired and wireless that are affected, nothing can connect to the internet even thought the router says it ok
10-06-2018 6:49 AM
I wonder if the router has reset correctly.
See post 41 here
https://community.plus.net/t5/Broadband/BT-Home-Hub-6-Smart-Hub-on-PlusNet/td-p/1349153/page/3
I would fully reset the router using both methods and try again.
10-06-2018 9:14 AM
Yeah it works.
Only thing different i did today was have all the cables plugged in when i reset it!
02-08-2018 11:19 AM
Tried to no avail. I own the BT Smart Hub and use it with fibre. I've followed the instructions to the letter but keep getting the same error - It's refusing to accept my Plusnet username and password in the hub settings - a dialogue pops up saying 'Error' with a red exclamation mark icon. There's no description of what the error is.
- I've fully reset the hub following instructions in the thread
- I've double checked my Plusnet username and password are correct and entered in the correct settings area
- I've cried. Lots.
I'm at a loss and had to resort to my old Plusnet router. Can anyone shed any light on this please?
02-08-2018 12:54 PM - edited 02-08-2018 1:00 PM
Are you using an odd character within your password for [email protected] . ? if so perhaps the BT Hub does not like it.
02-08-2018 1:03 PM
Thanks for the reply. I'm using a question mark in my password, so maybe that's it. I'll update my password and give it a try.
I'll report back!
- « Previous
- Next »
- My Router
