Upgrade from Hub1 to Hub2
Digsy
Apologies if this has been asked before (I did search)...
Quick and probably dumb question: If it possible to backup your Hub1 configuration and load it into a Hub2? I have quite a lot of custom settings for port forwarding and I'm not looking forward to having to re-enter them all manually.
2 REPLIES 2
Re: Upgrade from Hub1 to Hub2
@Digsy
The backup/restore are not compatible, so you'll have to look forward to manually entering all your settings.
I did find setting up port forward rules easier on the Hub two
Dan
Digsy
This is my sad face 😞
