Issue with new asus router
chonker
I have now a bought a new router a ASUS RT-AX86S. This is used with a Netgear DM200 modem. I previously had a Netgear R7000 and everything was fine. However with this new router, I can only access websites, netflix and iplayer are failing to work. Does anyone have any ideas? I can swap the routers back and everything is fine.
Cheers
3 REPLIES 3
Browni
Aspiring Hero
Fixes: 60
Re: Issue with new asus router
Check these settings under the LAN tab of the router's homepage (your WAN type will be different obviously)
Asus IPTV optionsAsus IPTV options
chonker
Still no joy. These are my settings if anyone can spot anything.
Screenshot 2023-04-04 at 17.59.36.pngScreenshot 2023-04-04 at 17.58.48.pngScreenshot 2023-04-04 at 17.58.09.pngScreenshot 2023-04-04 at 17.59.18.pngScreenshot 2023-04-04 at 17.58.48.png
chonker
Problem resolved!
In case anyone else has a similar problem. The default MTU size was bigger than the previous one. Once altered, it worked fine.
