Upgrade from FTTC to Full Fibre but keeping current router - pre-install sanity check!
snathe1978
Hi everyone.
I've got my upgrade from FTTC to Full Fibre booked for this coming Thursday (genuinely quite excited about it, too!) and just want to check something before the install goes ahead.
I'm currently using a TP-Link Archer VR600 VDSL modem/router for my FTTC connection and want to keep using this after the Full Fibre install by plugging the connection from the ONT into the WAN port on the back.
I've scanned back through the various posts on here and although I'm pretty sure I've got everything correct, I just want to confirm what I need to amend (or leave) in the settings on the router in order to keep using it once the install's done:
  • Change operation mode from "DSL Modem Router Mode" to "Wireless Router Mode"
  • Disable the VLAN ID
  • Leave connection type as "PPPoE"
  • Leave all other account settings (username, password etc) as they are
Is all this correct?
(Apologies if this has been covered before! Just want to make sure that there's as little a chance as possible that I could potentially end up not having a connection through my own stupidity, hence the sanity check!)
One other question; I currently have a static IP address. Will this remain the same with my move to Full Fibre, or will it change? (not the end of the world if it does)
Thanks!
4 REPLIES 4
Fixes: 579
Re: Upgrade from FTTC to Full Fibre but keeping current router - pre-install sanity check!
In a word, yes!
It should remain !,  but as they say, the only things guaranteed in life are death & taxes
One question, what speed full fibre have you ordered ? Can the vr600 handle the throughput of the higher speeds ? ( OK, that's strictly two questions )
snathe1978
In a word, yes!
Great, thanks for confirming!
I've only ordered the 74Mb speed purely for cost reasons (am having to keep to a bit of a tight budget at the moment) and as I'm currently on 67Mb FTTC I'm pretty sure it should handle it fine.
I'll let you all know how it goes anyway!
Fixes: 579
Yes, it will, handle that fine. I was a bit worried that on say the 500Mb or 900Mb , the vr600 might not be up to it.
snathe1978
Very pleased (not to mention very relieved) to report that my Full Fibre install has just completed and everything is working as expected!
Switched everything over in my router beforehand and it fired up with no issues when connected to the ONT.
Very happy with the install process too, took no more than an hour and went without a single hitch.
Thank you again @MisterW for confirmation!
