Tenda Nova MW3 mesh connection
barrylee
I have a plusnet hub one with a Tenda Nova MW3 mesh system for years it has been working perfectly last week there was a total broadband problem in Hastings when the whole town went down ,when the system was eventually returned my mesh system wont connect to the internet I have tried resetting it and have spent hours and tried everything that I can think of to try to connect it ,my PC is showing the Nova as a network and it seems to be picking up the wifi signal but it wont connect to the internet has anyone got any ideas .
3 REPLIES 3
Fixes: 1,495
Re: Tenda Nova MW3 mesh connection
Moderators Note
This topic has been moved from ADSL Broadband to My Router
Fixes: 244
Sometimes to be sure, it is worth asking the "daft" question...
If you connect direct to the router, do you get a connection to the internet?
Seanok
Hi @barrylee, I am having the same issue after an internet  outage on Friday.
I have tried everything and plusnet cant help.
Did you manage to get it fixed? I am stumped
