Technicolor tg582n remote access problem
billwiller80
hi guys,
I'm still using this router in a remote locality with adsl.
The problem that i wish to resolve is about remote access.
Everytime the router is restarted the remote access change from enable to disable.
I have to reactivate the service manually.
Is There a way to solve this problem ?
Plusnet firmware with
Software Release:10.2.2.B
Thanks in advice
Genno
2 REPLIES 2
Re: Technicolor tg582n remote access problem
Hi @billwiller80 welcome to the forum
Are you enabling remote access via the GUI or via telnet?
If I recall when I had one of these devices when using telnet to make changes a saveall command was required to make the change permanent.
Dan
billwiller80
hi dan,
after a saveall in telnet the service keep enabled even after the router turns off/on.
Thanks !
