Key password
- My Router
- Key password
Key password
15-07-2022 5:10 PM
Hi I lost my wireless key password how can I get it back or change it
Message 1 of 4
(1,397 Views)
3 REPLIES 3
Re: Key password
15-07-2022 5:20 PM - edited 15-07-2022 5:38 PM
@Hassio77 It should be on either/or the pull out card/plastic card supplied with the Hub, or on a sticker on the Hub.
Message 2 of 4
(1,393 Views)
Re: Key password
19-07-2022 11:56 AM
In case you changed the wireless key from the default on one of our routers you can change it back with a factory reset:
Message 3 of 4
(1,329 Views)
Re: Key password
19-07-2022 12:02 PM
Moderators Note
This topic has been moved from Broadband to My Router.
Message 4 of 4
(1,325 Views)
