Talk Talk Hub settings to use on Plusnet?
stephencoope
Hello, does anybody know if the Talk Talk Sagemcom Fast 5364 is locked to Talk Talk? I have accessed the router settings and changed as many as I can to those suggested by PlusNet but I can't connect to the internet. These are the settiings I have been able to change .. connection type PPP, VLAN id 101, DNS - obtain automatically. Any thoughts much appreciated, I am keen to try another router as the plus net hub seems to be dropping connection a lot - I have only switched to Plus net from Talk Talk last week and did not have any drop out issues with the Talk Talk router. Thank you Stephen
15 REPLIES 15
Fixes: 1,495
Re: Talk Talk Hub settings to use on Plusnet?
Moderators Note
This topic has been moved from  Fibre to My Router
stephencoope
thanks dvorak, are you able to help with the query?
Best Regards, Stephen
daveplus
Fixes: 10
@stephencoope
I don't know whether this helps but I moved home a couple of months ago and left the Plusnet Hub connected and switched on for 14 days before going back to my preferred separate modem and router and had no problems at all so maybe it is not the hub causing your problem.
Dave
stephencoope
Hi Dave,
Thanks for your help. If I am understanding you correctly did you have connection issues with the PlusNet hub  in the initial period after you moved which resolved themselves after a couple of weeks?
thanks
Stephen
Mads
Fixes: 79
Hey @stephencoope
Thanks for getting int ouch with us here.
You should be able to use that router with our service. To configure a third party router you will need to consult your manufacturer or your manual to gain access to your router and find the necessary pages.
Encapsulation Type:PPPoA (PPP over ATM)  if on ADSL broadband PPPoE (PPP over Ethernet) if on fibre
Username: your account [email protected]
Password: Your account password
You can also find more info on connecting here.
Thanks.
stephencoope
Hello Mads, thank you for getting back to me. Just to explain how I set it up … I connected the talk talk router to my laptop via ethernet cable and at the same time had the router connected to the ADSL socket on my main telephone socket. The attached photo shows what fields I could change on the router menu but in case you can't open it here is a summary of what I did ..
connection type - ppp
vlan id - 101
login - [Removed]@plusdsl.net
password - my usual account password
obtain DNS - automatic
I then clicked 'apply' but no connection to the internet (ps still had the ethernet cable at this stage)
Can you think of anything I did wrong or could try?
many thanks
Stephen
Moderator's note by Dick (Strat): Personal information removed from a public forum (to an area that staff can see).
daveplus
Fixes: 10
Hi Stephen
I had no problems at all. I just wanted to ensure I was using the Plusnet Hub in case there were problems during the initial period.
Dave
Beyhive
Fixes: 44
Hi @stephencoope,
Have you checked with Talk Talk if it can be used with another provider? as I am pretty sure most of their routers are locked to their connection.
 Faris
Fixes: 480
It could be that it was because you had the dsl cable connected before setting the Plusnet credentials so the router reverted to talk talk settings. Try setting the Plusnet user name before you plug the dsl cable in.
In addition you have not mentioned setting the PPPoE/A encapsulation. Is this set correctly?
bobpullen
Fixes: 331
I've had one of these units in the office since TalkTalk launched them, and had no luck configuring things back when I tried. That said, some of the options you've referred to definitely weren't open to me back then, so perhaps they've relaxed things since?
stephencoope
thanks Bob
stephencoope
hi, thanks for getting back to me. Excuse my ignorance but is this what I should do to access the talk talk  router menu....connect the talk talk router to my laptop via ethernet cable, and have my laptop connected to the internet via the plus net wi-fi? I could not see a PPoE/A drop down when I tried originally  only a PPP.  thank you very much for your help
Fixes: 480
@stephencoope
No. Connect your laptop to the talk talk router by Ethernet cable. Initially there should be no other connections either wired ot wireless.
Log into the router. You do not need an internet connection to do this. Set up the Plusnet credentials then when the router is trying to connect plug in the dsl cable between the router and BT filter.
The lack of encapsulation settings is worrying and this could be the issue that's locking you out.
If you can’t get this to work and want to try a better budget router then get a BT Smarthub 6 from the likes of EBay, they go for less than £20. Setting instructions are here  https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
stephencoope
thanks for your help, it's much appreciated. Is the BT hub likely to be better than the Plusnet one?
