TP Link Archer D7 settings for Plusnet ADSL
chapelbarn1
Hi all,  I just cant get this router to connect.  Ive been through the quick settings guide and have selected everything that is suggested, but just cant get it to connect.  Can anyone talk me through what to do?
21 REPLIES 21
Gel
Aspiring Champion
Fixes: 29
Re: TP Link Archer D7 settings for Plusnet ADSL
Best asked in correct thread ie MY ROUTER.
Have you had the activation confirmation e mail from PN, otherwise
pointless trying to connect.
Check here too;
https://www.plus.net/help/broadband/broadband-connection-settings/
Fixes: 420
Assuming you have a router supplied by Plusnet then connect that and confirm that you have a broadband connection. Assuming that is OK then go through the process in Chapter 4.1/ 4.2 of the manual https://static.tp-link.com/res/down/doc/Archer_D7(EU)_V1_UG.pdf. If you need to input the details manually you will find them here https://www.plus.net/help/broadband/broadband-connection-settings/
chapelbarn1
Thank you very much.  Broadband works on the Plusnet router.  I have tried to follow the guide listed on the router settings page.  Ive reset the router a couple of times too, but still cant get it to see the internet.  Ill give it another go shortly and will get back to you.  Stumped, Im afraid!
chapelbarn1
Thank you.  Any idea how I move this post to My router?
Gel
Aspiring Champion
Fixes: 29
Fixes: 420
@chapelbarn1
How far do you get with setting up the D7? The sort of error people make is to use the wrong password - you need to use the one that you use to log into the Plusnet Member Centre, NOT the router admin or wireless one.
chapelbarn1
Still nothing. I’m using my plusnet name xxx@plusnetdsl.net and it’s password too. Not the router one.
Fixes: 420
Can you log into the Plusnet Member Centre with the username and password? Have you set the router to PPPoA (routers tend to default to PPPoE) VCI/ VPI to 38/0 ant multiplexing to VC Based?
chapelbarn1
Yes all set as below but with username and password fcompleted
ATM Configuration
VPI(0-255):0
VCI(32-65535):38
Encapsulation Mode:VC-Mux
ATM QoS Type:UBR
PCR:0 frames/s
SCR:0 frames/s
MBS:0 frames/s
WAN Service Setup
Connection Type:PPPoA
PPP Username:
PPP Password:
Confirm password:
Connection Mode: Always on
  Connect on demand
  Connect manually
 Max Idle Time: minutes (0 meaning connection remains active at all times)
Authentication Type:
Default Gateway:
MTU(Bytes😞 (1480 as default, do not change unless necessary)
Enable SPI Firewall:
Enable IGMP Proxy:
Use IP address specified by ISP:
Echo request interval: (0-120 seconds, 0 meaning no request)
Set DNS server manually:
chapelbarn1
Here is a better screen shot of the settings
Fixes: 420
I’m clutching at straws now but it doesn’t look as though Save had been set.
Champnet
Aspiring Hero
Fixes: 12
sorry, pointless post
dannyboy75
Nothing leaps out from the screenshot, although the red text at the bottom is a bit odd ('Connection will be deleted...').
Also, you might want to change your WiFi keys now 😉
Strat
Fixes: 565
Moderator's note:
Topic moved to 'My Router'
