Is it possible to reset my router please
Jheanley
Hi, I have just setup a static IP via the website while on work computer, but really need to access my network at home asap.
I would be hugely grateful if some one could reset the connection so it picks up the new static IP. Is this something @bobpullen could do?
Best Regards,
Jules.
3 REPLIES 3
Fixes: 1,596
Re: Is it possible to reset my router please
Hi Jules.
I've just done that for you now so you'll see your router connect via your static IP in a moment.
Jheanley
Awesome! Thank-you so much.
Fixes: 1,596
No problems, let us know if you need any further help.
