Solid green light
Iain37
Solid green light
My router has stopped connecting and has a solid green light constantly. I've tried restarting it and I've held the factory reset button down for over a minute with no change.
As soon as it powers on it goes straight to a solid green light which blinks every 45 seconds or so.
Any advice on how to sort this?
6 REPLIES 6
Mustrum
Fixes: 81
Re: Solid green light
Is your phone line working?
Have you reported a fault?
PS - which router do you have?
Fixes: 1,495
Green light is only on in the start up phase, sounds like it’s faulty.
Iain37
I don't have a phone to test the phone line unfortunately.
I have the hub two.
Mustrum
Fixes: 81
A simple corded phone is one of the best tools you can have to narrow down broadband faults delivered over a telephone line - you can pick them up for less than £10 or even borrow one from a neighbour.
Not a lot anyone on here can do to help until you report a fault, resolution could be quicker if you were able to narrow it down to phone line or broadband.
bobpullen
Fixes: 331
Do you have any devices wired directly to the router? If so, do you still face the same problem if you unplug their respective ethernet cables?
Iain37
I left the router off overnight and did a factory reset before powering it up this morning. Problem seems to have disappeared now as router has connected.
Thanks for your input guys.
