Slow wifi
- My Router
- Slow wifi
Slow wifi
03-07-2019 7:48 PM
Been on plusnet for about 7 months, line speed minlmum guaranteed at 51mbps, OK on wired laptop but for some reason wireless speed has dropped to 25mbps on all wireless devices. Checked that nobody has piggy backed my router, anyone got any ideas?
Chris
Re: Slow wifi
03-07-2019 11:01 PM
1. Try separating the 2.4 abd 5 GHz bands, see https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1351966#M840 Try each band in turn and use the best.
2. Download a wifi sniffer app, I use Wifi Analyzer on an Android phone. Use this in your router locations and where you use your devices to monitor your and neighbours transmissions. If there are neighbours using the same band as you then go into your router advanced wifi settings and manually select a 'quiet' channel.
3. Make sure that there are no other wireless devices located close to your router.
Re: Slow wifi
04-07-2019 9:53 AM
Hi @Chrisvesey, thanks for your post.
We're sorry to hear that you're experiencing this drop in wireless speeds.
I'd definitely be looking at a wi-fi sniffer app as @Baldrick1 has suggested, as well as looking at the information on how to split the bands that he's helpfully provided.
Let us know how you get on!
Re: Slow wifi
04-07-2019 10:19 AM
Sorted slow wireless speed, reset router and now back to normal, thanks to those who suggested fixes. Can you remind me how to access my router and where I find the password,
Chris
Re: Slow wifi
04-07-2019 11:16 AM
That's really good to see Chris, thanks for letting us know. You'll be able to find the information you asked about here: https://www.plus.net/help/broadband/router-setup-guides/ - Adam
