Slow connection within local network
FIXED- Subscribe to RSS Feed
- My Router
- Slow connection within local network
08-04-2021 9:49 PM
Fixed! Go to the fix.
Re: Slow connection within local network
09-04-2021 7:22 AM
Also d/load a wifi analyser programme, to check which channels are most un use in vicinity of your house;
then choose least used channel, and input manually on your router.
09-04-2021 8:54 AM
09-04-2021 9:54 AM
Why not join those of us who have given up with Plusnet hubs? You can get a far superior BT Smarthub 6 for peanuts on auction sites. Settings are here https://community.plus.net/t5/My-Router/Using-A-BT-Smarthub-An-Update/m-p/1795292#M24601
09-04-2021 10:09 AM
I was thinking of this bth.
Does BT Smarthub allow you to specify custom DNS? I'd love to use PiHole to filter out ads and this isn't possible with the Plusnet hub.
14-04-2021 3:10 PM
Spent some time fiddling with wi-fi driver settings (iwlwifi) and managed to get the connection working again. Still not sure what caused the issue in the first place.
15-04-2021 2:44 PM
With the Business version of the Smarthub you can define which DNS servers you wish to use. This feature is not available on the residential versions.
- My Router
