Setting up hub two
Timalay
Setting up hub two
Basically I bought a Hub Two online, what details will need to input when setting it up for the first time?
24 REPLIES 24
Fixes: 388
Re: Setting up hub two
Your username and account password.
Fixes: 480
@Timalay
What do you mean by Hub 2? A Plusnet Hub 2 (can you buy them on line?), A BT Home Hub 2, a BT Smarthub 2 or another ISP’s Hub 2?
Timalay
Yes, I did mean Plusnet Hub Two, sorry.
bobpullen
Fixes: 331
@Timalay - I'd stongly suggest dropping me a private message containing your account username and the hub's serial number so it can be correctly associated with your account.
Given how new this device is, there's every chance it's still linked with the seller's account. This won't cause any immediate problems if you manually overwrite the broadband username/password with your own, however it could well cause complications in future if you ever need to factory reset the device.
Timalay
@bobpullen Thanks for that, being a broadband-only legacy user, I doubt PlusNet would let me sign up for a new contract.  I'll drop you a line when does arrive.  Thanks for not judging me for buying one online.  My Plusnet Hub One is starting to show its age.
Fixes: 585
Apparently, yes! There's a few on the well known auction site, although one is actually a Hub One!
Timalay
eBay, but then again there's nothing you can't buy there it seems.
Correlated
This shouldn't be allowed surely?
Plusnet need to introduce return item or get charged at the end of contract imo.
Bogbody
Fixes: 4
Yes, just looked - 3 come up straightaway.
Look like brandnew, shiny, unused Plusnet Hub 2 routers. 🙂
Timalay
@bobpullen where would I find the hub's serial number?
Fixes: 388
@Timalay serial number is on the label - possibly starts NQnnnnnn?
Fixes: 388
Sorry, @Timalay Hub2 serials appear to be in the format: +nnnnnn+nnnnnnnnnnn , where 'n' is numerical.
Correlated
Name and shame the seller bobpullen
bobpullen
Fixes: 331
@Timalay - it's printed on a sticker underneath the removable plastic tab with the Wi-Fi password etc. on it.
