Router
rooky
Router
Hi. How do I set the hub so I can select which band to connect a device to like 2.4 or 5
7 REPLIES 7
Fixes: 392
Re: Router
Hub1 or Hub2?
rooky
Re: Router
Hub 2
Fixes: 392
Re: Router
I don't think you can - the device will 'find' the best band to connect to. Why do you need to specify the band?
rooky
Re: Router
Cos my coffee machine keep losing connection and Jura said it need be connected to 2.4
Fixes: 392
Re: Router
Ah. In that case, try temporarily disabling the 5GHz, connect your machine whilst only the 2.4 is available, then re-enable the 5GHz.
Fixes: 480
Re: Router
Moderator's note:
Thread moved from Broadband to My Router
Fixes: 587
Re: Router
@jab1 you think correctly, you can't separate the bands on a Hub 2
