Access control not working
Mrc1
I've got a Hub 2 running version v0.10.00.04201-PN of the firmware.
I can't get the access controls to take effect.
I understand HOW to set up access controls.  I've tried doing it by device and by setting up a group.  I've tried making sure my son's Playstation always uses the same IP address but it still isn't respecing the access control I have set up on the router,
The time on the router is set correctly.
Is this a known issue on this router?
Has anyone else had this issue?
It doesn't look like I have the ability to update the firmware.  is this normal?
Any other thoughts?
Many thanks.
7 REPLIES 7
Fixes: 392
Re: Access control not working
@Mrc1 Re: Firmware - you are on the latest f/w, and no you can't update it, that is done by PN - when they issue an update.
Can't help with the access control, you need someone with more knowledge than me - sorry.
@Mrc1
There is a help section for the Hub Two here https://www.plus.net/help/broadband/router-user-guides/hub-two/
Hopefully the instruction will be of use.
amarshe
On the firmware - as Plusnet now do fttp I’m happily back with them. I notice that my hub 2 is on the latest firmware and the ‘Firmware updated’ is ‘Unknown’.
My Bt hub 2 had several updates during my two year contract; is the Plusnet hub 2 firmware just better designed? Seems strange that updates seem less frequent.
Also seems that the Plusnet hub 2 doesn’t restart every 14 days? If so another bonus of being back with Plusnet!
@amarshe
I believe this will have a date if the Hub was updated remotely, mine indicates Firmware updated: 30-Jun-2023
I wouldn't be worried about the lack of updates, they are only issued when a new feature is added or a deficiency found. Many routers are the same.
The Hub would only be rebooted by plusnet after an firmware upgrade, my Hub System uptime: 283 Days 8 Hrs 24 Mins
amarshe
Awesome, thanks.
Mrc1
Thanks Dan.  That's a bit too high level and general.
I can see HOW I'm meant to configure blocked time but it just isn't taking effect.  ....Yes I am saving my settings!  😉
@Mrc1
Does the Access control work at all?
Access Control >Pause >Pause all Internet access: YES
Is it possible to Pause the individual devices, does that work?
When you set the access control do you see Screenshot 2024-04-10 084741.png against the device IP Address when viewing Home >My network >All devices?
