Router
stathe
Re: Router
Thank you    So how do I get there as it is so small
Fixes: 388
Re: Router
Home>Advanced settings>Technical log
stathe
Re: Router
Yes Thank you with a dreaded password   I see  Thanks again
stathe
Re: Router
How about the SNR which was displayed on my Net gear how would I calculate or see ?Huh
Fixes: 388
Re: Router
This (slightly edited for security) is what should show:
Product code:Plusnet Hub Two
Serial number:XX
Firmware version:v0.08.00.08297-PN
Firmware updated:16-Nov-2022
Board version:R01
GUI version:1.9 16_08_2022
DSL uptime:0 Days 6 Hrs 12 Mins
Data rate:5.584 Mbps / 34.976 Mbps
Maximum data rate:5.675 Mbps / 37.731 Mbps
Noise margin:6.1 / 7.2
Line attenuation:11.8 / 21.9
Signal attenuation:11.6 / 19.0
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:74.9 MB Uploaded / 511.1 MB Downloaded
Broadband username:
2.4 GHz wireless network name:
2.4 GHz wireless channel:Smart (Channel11)
5 GHz wireless network name:
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:On
MAC address:XX
Software variant:-
Boot loader:0.1.7-PN (Thu Nov 30 09:45:22 2017)
Can you post what you see on that page, edited as above, please?
stathe
Re: Router
Yes I can see that but dont want  my settings altered as theey are fine as they were
stathe
Re: Router
Plusnet Hub Two Manager
This is a list of your Plusnet Hub settings and current statistics.
Serial number:+108417+2237017087
Firmware updated:10-Mar-2023
Board version:R01
DSL uptime:1 Day 14 Hrs 33 Mins
Data rate:799 Kbps / 2.326 Mbps
Maximum data rate:772 Kbps / 2.444 Mbps
Noise margin:4.4 / 2.8
Line attenuation:43.3 / 70.0
Signal attenuation:43.4 / 75.0
VPI/VCI:0/38
Modulation:G.992.5(ADSL2+)
Latency type:Interleaved
Data sent / received:1.3 GB Uploaded / 5.1 GB Downloaded
Broadband username:[email protected]
2.4 GHz wireless network name:PLUSNET-37C9RX
2.4 GHz wireless channel:Smart (Channel 11)
5 GHz wireless network name:PLUSNET-37C9RX
5 GHz wireless channel:Smart (Channel 36)
Firewall:On
MAC address:AC:B6:87:9D:6F:FD
Software variant:-
stathe
Re: Router
Yes not sure how to copy Where is SNR
198kHz
Fixes: 42
Re: Router
Board version:R01
VPI/VCI:0/38
BT technician (Retired)
Fixes: 1,495
Re: Router
this is your SNR: Noise margin:4.4 / 2.8
looks like it is set to 3 which is (I assume) what you want.
