Router
stathe
Router
I want a new router so How do I get one ?Huh
24 REPLIES 24
Fixes: 388
Re: Router
Either  buy one yourself or ask for one at renewal. Why do you want one?
Mav
Fixes: 518
Re: Router
Moderator's note(s):
Thread moved from Broadband to My Router.
Forum Moderator and Customer
stathe
Re: Router
Wi fi not working so would like another from Plusnet soon
Fixes: 388
Re: Router
'Wi-Fi not working' is not a helpful reply. Do you mean wireless devices are unable to get a signal, or you cannot connect to the internet?
willcutforth
Fixes: 113
Re: Router
Hey there @stathe which router is it that you have at the minute? What's the issue with the current one if you don't mind me asking? I can look at getting you another one.
 Will Cutforth
stathe
Re: Router
It is a Netgear N 600   DGND3700/2 has been very good on my long line and is OK but sometimes WI Fi to rest of house fails and needs to be switched on and off I dont want any of my settings altered by the Plusnet people Thank you
stathe
Re: Router
Yes wireless sometimes fails
willcutforth
Fixes: 113
Re: Router
No worries, it will be £6.99 for the postage and packaging of the router is that ok?
 Will Cutforth
Fixes: 388
Re: Router
Deleted in response to @willcutforth 's reply.
stathe
Re: Router
Yes O K will it go on my bill Thank you
willcutforth
Fixes: 113
Re: Router
It will be added to the bill you are right. Please can you reply to https://www.plus.net/wizard/?p=view_question&id=232157026 and I will sort it?
 Will Cutforth
stathe
Re: Router
One of my sons has fixed up the new Plusnet 2 router How can I check the noise margin SNR ?it shows download and upload Mine needs to be low
stathe
Re: Router
Line attenuation SNR  and Noise margin Huh  which I could see on my Netgear
Fixes: 388
Re: Router
This page:
