My very variable connection
Ben1
My connection is once again giving me connection problems; the desktop computer is generally fine, but my iPhone and iPad are often very variable or won't connect at all. I have a BT Hub 6, which I have restarted from the web interface. Should I try and get hold of a BT Smart Hub 2? I wonder what I can do to improve matters, thank you.
3 REPLIES 3
Fixes: 388
Re: My very variable connection
Right, @Ben1 . My first suggestion - totally shut down and restart the Apple devices, they can, and do, get 'confused' at times.
Fixes: 480
@Ben1
If your PC is OK then this sounds like a WiFi problem.
The Smarthub 2 wireless is no better than the original Smarthub, in fact it has a major disadvantage, that is, you can't separate the bands. Two things to try:
1. Split the bands on the Smarthub. You will find instructions https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85.... Try each band in turn and use the best.
2. Use a WiFi sniffer app, I use WiFi Analyzer on an Android phone. With this 'see' which channels your neighbours are using. Check both at the Hub location and where you use your devices. Manually set, in the Hub advanced wireless settings, a channel that has the lowest transmissions from others at both locations, this can be a bit of a compromise.
Ben1
Thank you folks, that gives me something to get my teeth into.
I realise that it could be related to my VPN, which is only active on the desktop iMac. I'm looking into that as well.
