Router not showing "Devices currently connected"
Tinka8ell
Trying to access my Raspberry Pi and it is no longer there - apparently.
Connected to the router and the initial display shows no devices connected:
Devices currently connected to your Plusnet Router: shows an empty table.
Refresh button makes no difference.
As I am connecting from my laptop to do this, it at least should show up.
I am using an echo dot, and that is happy downloading content from the internet, as would be my phone, and my chromcast.
So why no names shown?  There was a list last time I reset the router, but the list is now gone.
Is there anyway to set names to the devices in the list, once I get them back?  Having some strange names is not a lot of help.
Helpdesk details:
1 - Product name: Plusnet Router
2 - Serial number: N7190191B001358
3 - Firmware version: 7.275.11_F2704N_Plusnet
4 - Board version: F@ST2704N
5 - Mode ADSL
Can I allocate fixed addresses to any of these devices, or do they get a new one each time they connect?
7 REPLIES 7
RandallFlagg
Fixes: 75
Re: Router not showing "Devices currently connected"
Hi @Tinka8ell
I must confess, I don't know the answer to this, BUT I do know some very experienced chaps who might.
@Gandalf @bobpullen - Could you possibly shed any light on the questions that @Tinka8ell has raised?
Dave
Fixes: 1,495
Moderators Note
This topic has been moved from ADSL Broadband to My Router
Fixes: 1,660
I'm aware of an acknowledged issue with this on the Hub One but not the Hub Zero (Unsure if that issue has been fixed yet by the way)
Did you say you've tried a factory reset of the router by pushing a paper clip into the reset pin hole at the back for 15 seconds?
If that doesn't sort it out, over to @bobpullen hopefully he'll have more advice on this for you. Smiley
With regards to setting names and fixed IP addresses to your devices if there's no option to in the router control panel there's probably no way this can be done Sad happy to be wrong though.
Alan_S
I have the same router, 7.275.11_F2704N_Plusnet (Hub 0?), and it does lose attached devices or forgets their names. After a router reboot all devices are usually there but they have dynamically assigned IP addresses. I made a copy of the device list and added friendly names for future reference.
Currently the only device missing from the list is the laptop (192.168.1.2) that is displaying the router management page!
Network Device MAC Address IP Address
Wi-Fi: android-e12091075f7bc4db e0:2c:b2:d0:27:d7 192.168.1.1
  Unknown-a8:3e:0e:22:65:a6 a8:3e:0e:22:65:a6 192.168.1.3
  EPSON67B03D 44:d2:44:67:b0:3d 192.168.1.5
  Notebook c4:17:fe:08:a1:dc 192.168.1.6
  Unknown-b8:27:eb:12:29:4c b8:27:eb:12:29:4c 192.168.1.4
For the Raspberry Pi I have set up a Windows Remote Desktop Connection (windows search rdp) to raspberrypi.local so I do not need to know its IP Address.
If you want to set fixed addresses you need to open http://dsldevice.lan/expert_user.html or http://192.168.1.254/expert_user.html Login <Advanced Setup> <LAN> Disable DHCP Server, click <Add Entries>, enter the MAC Address with desired IP Address (default is 192.168.1.n where 1<n>253). <Apply/Save>. I think a router restart is required for this to take effect.
  Disable DHCP Server
  Enable DHCP Server
       Start IP Address:
       End IP Address:
       Leased Time (hour):
       Static IP Lease List: (A maximum 32 entries can be configured)
MAC Address IP Address Remove
B8:27:EB:12:29:4C 192.168.1.4
If the router has not displayed the MAC address you can open a command prompt (windows search cmd) and ping the R/Pi (N.B. the '-4' means use IP v4).
C:\windows\system32>ping raspberrypi.local -4
Pinging raspberrypi.local [192.168.1.4] with 32 bytes of data:
then:
C:\windows\system32>arp -a
Interface: 192.168.1.2 --- 0x6
Internet Address Physical Address Type
192.168.1.1 e0-2c-b2-d0-27-d7 dynamic
192.168.1.4 b8-27-eb-12-29-4c dynamic
192.168.1.254 8c-10-d4-27-ea-7a dynamic
macvendors.com tells me that e.g.
192.168.1.1 e0-2c-b2-d0-27-d7 is from 'Lenovo' and
192.168.1.4 b8-27-eb-12-29-4c is from 'Raspberry Pi Foundation.
BTW, When I swap routers (between 2704N and BT HH6A) my R/Pi does not automatically connect. I connect an Ethernet cable directly from the Laptop to the R/Pi and the above RDP connection (to raspberrypi.local) just works and I can then swap the connection.
HTH, Alan
Tinka8ell
Thanks Alan
you have given me much to think about.
I tried to record the mac addresses using arp -a ... there are some interesting ones not on my network!, but otherwise worked well for the PC's and Pi's that I know what ip address they are at.
Then I went to look for DHCP ... no there is a problem ...
Home
Basic Settings
Advanced Settings
Helpdesk
DNS
Wi-Fi
Access Control
Port Forwarding
Firewall
DynDNS
Management
Advance settings does not give me Lan.  None of these give DHCP options.  The basic has even less:
Home
Basic Settings
Advanced Settings
Helpdesk
Broadband
Wi-Fi
I suspect I may need to go back to my BT or Sky routers and manually configure them to connect to PlusNet as this router does not have the options I need.
Alan_S
As I said before, you need to login to the Expert User pages; what you show are the default Plusnet pages.
Just click one of these links:
Plusnet 2704N Expert UserPlusnet 2704N Expert User
Click:
[Advanced Setup]
Then
[LAN]
Plusnet 2704N Advanced  Setup LANPlusnet 2704N Advanced Setup LAN
Disable DHCP Server
Click [Add Entries]
Enter Desired MAC and IP Address
Click [Apply/Save]
Make sure o Enable DHCP Server is selected
Settings take effect after Reboot / Restart Router
(via Management page)
I think most would advise you to use your BT Home Hub.
Alan
Tinka8ell
Thanks Alan.
I confused: http://192.168.1.254/advanced_settings.html
with: http://192.168.1.254/expert_user.html
It is so annoying when the desire to be "user friendly" actually makes things "useful opaque".
Thank you again.  There does not seem to be an option for giving names to the fixed addresses.  On reboot, they get their broadcast names, but I will see if they are still there after a period, or they lose their names again.
