Router noise
- My Router
- Router noise
Router noise
18-12-2017 10:38 PM
My router is making a near constant chattering/scratching kind of static noise and it is driving me mad.
I've seen other threads on here where people got their router replaced, so what are the chances I can get a new one and it won't have this issue?
Re: Router noise
19-12-2017 12:44 AM
You will have to contact Plusnet.
Good luck!
Re: Router noise
19-12-2017 7:28 AM
Re: Router noise
19-12-2017 8:55 AM
Only electro-mechanical components make noise and I'm pretty sure there are none of these inside a router. So if you hear noise I can only think it must be from an electrical component that is failing and what you hear is small sparks. If so, this cannot be safe.
Re: Router noise
19-12-2017 10:40 AM
Sorry but this is not correct. There are wound components in routers and unless they are properly vacuum impregnated the coils can vibrate at a resonent frequency that is an audible submultiple of the digital data rate being transmitted. This is irritating but in no way dangerous.
Re: Router noise
19-12-2017 2:37 PM
Re: Router noise
19-12-2017 2:59 PM
Moderator's note by Dick (Strat) Topic moved to 'My Router' board.
Customer and Forum Moderator. Windows 10 Firefox 86.0 (64-bit)
Re: Router noise
19-12-2017 8:57 PM
Youcan nearly always use live chat - it's open daily BUT , sometimes it can be hard to find , especially if you're using a tablet like an iPad .
Plus net needs to figure out how to fix this for tablet users . Not everyone uses a desktop machine
On the plus side I managed to contact tech support this evening by phone with no wait . peak time too 6.00pm. Try calling !
Re: Router noise
20-12-2017 4:47 PM
Hi there.
It seems some of the Hub Ones are making this noise when a 5GHz connection is in use.
Try splitting the 5GHz and 2.4GHz SSIDs and connecting devices on each frequency to see if the problem is isolated to just the 5GHz connection.
Re: Router noise
21-12-2017 11:48 AM
I had a couple of Hub Ones and they both made that sound when 5Ghz was in use. Got my own router in the end and no noises.
