Router keeps dropping out: "tcp reset attack is suspected"
Re: Router keeps dropping out: "tcp reset attack is suspected"
Given that  "PPPoE is down after 23 minutes uptime" is quite a short time for the PPP connection to be up,  there could be an as yet undiagnosed line fault causing the PPP to drop.
Try running through the Plusnet broadband troubleshooter - Quickest way - troubleshoot by text  to see if that finds anything wrong.
LawTurley
Yeah, I've done that and they've confirmed there is a fault of some kind, engineer booked for Monday. Fingers crossed!
bobpullen
Fixes: 330
@Dan_the_Van wrote:
These messages are a port forward rule to a device which is currently turned off, the connection if from 147.70.179.19 which appears to be M247 Ltd
09:56:10, 20 Jul. IN: ACCEPT [57] Connection closed (Port Forwarding: TCP [192.168.1.66]:39579 <-​-​> [146.90.163.248]:39579 -​ -​ -​ [146.70.179.19]:19388 CLOSED/SYN_SENT ppp3 NAPT)
09:56:10, 20 Jul. IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.66]:39579 <-​-​> [146.90.163.248]:39579 -​ -​ -​ [146.70.179.19]:19388 CLOSED/SYN_SENT ppp3 NAPT)
You've got the IP wrong @Dan_the_Van. The first octet is 146, not 147; it's the OP's public IP address.
The problem is the fact that the line is losing sync. Below are line initialisations from yesterday...
Hopefully the engineer sorts it.
Fixes: 380
Not a nice picture, @bobpullen 😞
LawTurley
I don't really understand what that graph is @bobpullen, but I take it that it means there's a physical issue with the line in order for it to lose sync, rather than a router issue?
Fixes: 380
@LawTurley - Correct, hence your engineer visit.
Fixes: 146
@bobpullen
sorry for the typo,
inetnum: 146.70.179.0 - 146.70.179.255
netname: M247-LTD-London
descr: M247 LTD London Infrastructure
inetnum: 146.90.128.0 - 146.90.255.255
netname: PLUSNET-DIAL-ADSL
descr: Dial-up and ADSL pool
Dan
bobpullen
Fixes: 330
@Dan_the_Van - ah, I see now. Had overlooked that there were two distinct IP's starting 146.
LawTurley
The engineer has just left and has concluded that it's a problem with the router, and has ordered me a new one. I'm frankly a bit baffled, as i seemed as if you guys were confirming it was an issue with the line/connection not a router problem.
Fixes: 380
@LawTurley That engineer needs sacking. The graph @bobpullen posted earlier clearly shows network - i.e. OpenReach drops - your Hub has nothing to do with it! Standard OR brush-off when they can't be bothered.
