Why does my hub 2 emit very high levels of EF & RF?
RobJ71
I am connected to my hub via ethernet, and the Wifi is turned off (allegedly), why such extreme readings? This is from a distance of 1 foot from the router.
5 REPLIES 5
Fixes: 124
Re: Why does my hub 2 emit very high levels of EF & RF?
@RobJ71 welcome to the forum.
How did you turn off the wifi, using the disable all wireless switch or the individual channels?
Mav
Fixes: 518
Moderator's note(s):
Thread moved from Broadband to My Router.
Forum Moderator and Customer
RobJ71
Thanks for welcoming me, I disabled by turning off both 2.4ghz and 5ghz bands.
Fixes: 124
The Hub two has two hidden wireless signals, if you disable all wireless that will turn them off as well
HTH
RobJ71
@Dan_the_Van thanks very much, this has solved the issue. I did not see that additional setting there.
