Router is not working properly
aimless101
I have a Plusnet hub 2 router and it has worked fine for years
just recently trying to control it via hub manager has become very hit and miss
eg save button doesn’t work
cant set schedules without it interfering and scheduling the wrong devices
disconnecting devices when I have accessed the manager online
So far I have reset the hub and set back my passwords.
I suspect I need a replacement hub
How do I get one please?
thanks
3 REPLIES 3
Christopher_G
Fixes: 5
Re: Router is not working properly
Hi @aimless101
Please try clearing your browser cache and trying a couple of different browsers, if possible. If it still isn't working, it may be worth trying to reset the router using the pinhole on the back of the device.
Let us know if it's working any better after that.
Chris
aimless101
Hi
I tried all of that and it still isn't letting me use the settings on the website
Do I need a new router
In fact now I can't set any user times Sad
thanks in advance
Amy
Linzi_H
Hi @aimless101
You can Report A Problem using the text service, and a member of the support team will get back in touch to help with the next steps after running some checks.
Linzi
