BE550 Internet Connection
tomburch
Newbie here.
I have a full fibre connection using the Hub2. Unfortunately this doesn't support a USB connection on the rear. I wanted to get a new router to support USB storage devices. Ultimately the aim is to get rid of MS one drive as I don't use office enough to make the subscription worthwhile. I bought a TP link BE550 router as this was recommended in a leading consumer magazine. I've followed the instructions on the forum about setting the Hub2 to bridge mode. However, when I do this the pink light on the hub two illuminates which tells me that bridge mode is not supported with full fibre.
I can access into the BE550 with no issues.
How can I get the BE550 to connect to the internet via the Hub2? Any gentle step by step guide would be appreciated.
TIA
Tom
3 REPLIES 3
Fixes: 583
Re: BE550 Internet Connection
@tomburch
You don't!. Just remove the Hub2 completely, connect the BE550 WAN port directly to the ONT. Configure the Be550 Internet connection for PPPoE with your Plusnet credentials. Username is <youraccountname>@plusdsl.net and password is the one you use to access the member centre (https://www.plus.net/member-centre/login)
@tomburch
Welcome to the forum.
You need to setup using this:-
"Internet connection type" - PPPoE  using your account username in this format [email protected]
"Password"  - is the one used for the members centre.
IPTV/VLAN is set to Off
ONT LAN port to BE5500 WAN port, cat5e or above cable
tomburch
Thank you. Router now up and running.
