Router connection
Bbylett
Router connection
My new plusnet router is continually being dropped by ipad. Nothing else is being dropped. Tried all usual solutions, e.g. deleting and starting again. Getting very annoyed.
1 REPLY 1
bill888
Champion
Fixes: 40
Re: Router connection
Which hub do you have?
https://www.plus.net/help/broadband/router-setup-guides/
If you have superfast fibre, it will probably be the Hub One.
In which case, try separating the 2.4 and 5 GHz wifi.  Known issue with iOS devices.
https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/td-p/1351950
If you find the 5 GHz wifi stops working for all devices, it may be the issue described here afflicting the Hub One.  You would need to request an update for your hub
https://community.plus.net/t5/My-Router/Hub-One-5GHz-WiFi-issue/td-p/1696363
