Best wifi extender for hub 2?
samk2310
We have a hub 2 in the living room and a r200 TP Link extender upstairs.
They are both on separate networks and it's annoying. Is there any solutions that can be on 1 network so that if I walk from downstairs to up, it changes seamlessly...without having to manually change?
3 REPLIES 3
Re: Best wifi extender for hub 2?
@samk2310 welcome to the forum.
Have you tried cloning the Hub Two wireless name on the R200 devices? In most cases this should solve your issue.
The another option is to investigate a mesh system, this would require new hardware.
Dan
Fixes: 1,495
Moderators Note
This topic has been moved from Full Fibre to My Router
TheJayBee
I can recommend the BT WholeHome WiFi and disable the WiFi on the PlusNet router.  I’ve been doing this for a few years and it’s brilliant.  I have 3 WholeHome WiFi units.
