Router Power
- My Router
- Router Power
Router Power
Router Power
09-07-2016 9:24 AM
I've noticed that even though my Asus RT-N66U router is at full power under the latest firmware that my signal strength, both 2.4 and 5G, is around the -40 level according to Wifi Analyser even though it's only about 3 metres away at the other side of the room and in line of sight.
However, I have a neighbours BT router in sight of Wifi Analyser that consistently delivers a more powerful -30 signal. I know that the BT router isn't next door, the semi attached, so must be 2 doors away as my other neighbour doesn't have the internet.
I've looked online and found other similar complaints about BT Wifi.
So do the BT routers break the 100mw limit ?
PS: I've manually assigned my channels to be away from the BT ones.
Re: Router Power
Re: Router Power
09-07-2016 10:54 AM
It shouldn't really matter which signal is stronger than the other, so long as it's strong enough to get the necessary amount of bandwidth to where it's required. Even if they were on the same channel, it wouldn't matter which signal was stronger, so long as they could detect each other, they should co-exist reasonably well, trying not to interrupt each other.
Re: Router Power
Re: Router Power
09-07-2016 1:58 PM
That was with HH3 routers at the time.
