Router Noise PlusNet One hub
FIXED- Subscribe to RSS Feed
- My Router
- Router Noise PlusNet One hub
01-04-2018 10:29 PM
Similar problem to other posters, in the last 2-3 weeks my One hub makes constant static-y/hiss noise. Doesn't seem to affect performance but is getting loud enough to be noticeable (the hub is in the living room connected to the master socket and I can hear it over the TV with soundbar on!)
If you could arrange a new one and I will send you back the old one so you can take a look/put it out of its misery. Thanks.
Ewan
Fixed! Go to the fix.
Re: Router Noise PlusNet One hub
02-04-2018 2:51 PM
04-04-2018 10:28 AM - edited 04-04-2018 11:00 AM
This morning the postman shoved a parcel through my door, tearing off the label in the letter box. It is a "Plusnet Hub One Self install Pack". I rang customer services (I don't want charging for something I didn't order) and the lad was quite blazee. He had no idea why I had received a router when I hadn't ordered one. I could keep it or he would send a return label (which would entail my driving ten miles there and back to the Post Office - no thank you - you can collect it if you wish) but he was adamant that I wouldn't be charged and I could keep it. Had I been on the forum, well, yes, I had on the the topic of a re-sync. after a power interruption. Was I "misterashford74?" well, no. I noticed an order no. on the remains of the label and quoted it to the lad. "That's for misterashford74" he said. Hadn't he better get onto misterashford74? He did not seem at all interested and could't understand any of it.
Neither do I but I can see that there has been an almighty [-Censored-]-up. I would like to know the reason and I am very, very sure that so would you @Misterashford74
It took me a while to track down this thread and post, but I hope that I have been of some help!
EDIT: Just for the record, there was no need for a censor, the term I used is not rude, it's a navel term referring to a sail being in a wrong state!
04-04-2018 11:05 AM
Sorry about that @JamesE
Looks like Adam might have accidentally RMA'ed your router instead of @Misterashford74's.
I've replaced your router now for you Ewan. You should receive it shortly.
04-04-2018 11:10 AM
That's OK, thanks @Gandalf. I think that's the case as I have just noticed that inside the outer plastic wrapping there is what could well be the returns (blue) bag referred to by Adam. I haven't opened it and won't do so.
04-04-2018 11:17 AM
No worries. Whenever we RMA a router, a returns bag is automatically sent out.
Don't worry if it's too much inconvenience for you to get to the post office.
I'd recommend just keeping it for yourself, donating it to a friend, or dispose of it in an environmentally friendly way.
I can confirm we won't charge you for it.
04-04-2018 1:59 PM
Thanks James, from the read of the thread that text PlusNet sent means a(nother) router is on its way to me. The current one does work, it just makes rather sinister hissing sounds that are audible above the TV soundbar!
04-04-2018 2:57 PM
I have been fantasising with the connection between what I believe to be the censored word and a sail in the wrong state on a navel.
It could of course be no more than a typo that's confusing me!
04-04-2018 5:36 PM
Oops! Oh dear! It reminds me of a paper I once did about the golden section when I found a reference to the fact that apparently the ratio was considered to be that of a woman's navel to her height, and some wag in some journal, probably to do with ships, made some comment about its connection with naval architecture.
Sorry about the blunder but I'm entitled to a few at my age.
@Gandalf Thanks for the reassurance - I might as well keep it then as a spare in case mine should go wrong.
04-04-2018 10:21 PM
- My Router
