Extender - Netgear
pb123
Extender - Netgear
can't connect nether ac1200 extender - the device light on extender doesn't come on which presumably means no connection - is there a setting in the router or Plusnet firewall that could be affecting this?
Tags (2)
2 REPLIES 2
BillyCool
Re: Extender - Netgear
@pb123 I'm assuming it's got power? (i.e the power light comes on?)
Have you tried hard wiring to see if that's working and providing internet?
Fixes: 360
I assume that you are aware that there is an on/off switch on the side of the extender? Have you followed the instructions in the manual Chapter 2 see http://www.downloads.netgear.com/files/GDC/EX6120/EX6120_UM_25Aug2015.pdf?
