Router Hacked??
- My Router
- Router Hacked??
Router Hacked??
06-03-2017 10:11 AM
I have run an avast check and it is saying my router has been hacked and it is a serious threat, I do not know how to tell if it has been or not.
I have attached a screen shot of what avast has said. Can anyone help?
Thank you,
Sharon.
Re: Router Hacked??
06-03-2017 10:19 AM
Navigate to the dns settings (depends on your router where they are) You will need the user/password for the router to access them.
Check they are either the PN servers or set them to 8.8.8.8 & 8.8.6.6 (Google's servers)
CHANGE the router password if it is still the default one.
Re: Router Hacked??
06-03-2017 10:31 AM
@HairyMcbiker - That should be 8.8.4.4 not 8.8.6.6
Re: Router Hacked??
06-03-2017 10:32 AM
Re: Router Hacked??
06-03-2017 10:43 AM
Hi, Thank for the advice, I have a hub one router and I cannot find the PN Servers. Sorry I'm not very good at this kind of thing.
Thanks,
Sharon.
Re: Router Hacked??
06-03-2017 10:47 AM
given the difficulty of hacking the Plusnet router - compared to piggybacking onto the wireless - can you provide the exact report as it may well be a false alarm based upon the TR69 facility
Re: Router Hacked??
06-03-2017 10:55 AM
Since it is a hub one, just ignore it. It is scaremongering wanting you to buy yet another of their products.
Re: Router Hacked??
06-03-2017 11:22 AM
You can only amend to suggested DNS settings above by adjusting on each connected device.
