Router Faulty
MrDonaghey
Router Faulty
I've had my router for quite some time now and it's starting to show signs of its age.
It turns itself off intimately with no lights or activity how do I go about ordering a new one
Tags (2)
11 REPLIES 11
Fixes: 380
Re: Router Faulty
How long have you had it. and which version is it?
MrDonaghey
Re: Router Faulty
I have the Plusnet Hub Two and I've had it for 3+ years.
Fixes: 380
Re: Router Faulty
The easiest way to sort this is to ring Customer Support tomorrow and ask for their advice.
ExForce9
Re: Router Faulty
@MrDonaghey wrote:
... starting to show signs of its age ...
... turns itself off intimately with no lights or activity
Yeah, I've known women like that !  Shocked
However, if your router is turning off intermittently, the most likely cause of that is the mains power plug failing.
Is the power adaptor getting unusually hot, buzzing, or whining ?
If you have the power plug from a previous Plusnet or BT router, if the DC plug fits, then you could try using that to see if the problem disappears ?
If you still want a replacement router, you could get a far better device from Argos, eBay, or Amazon, rather than simply putting up with yet another Plusnet Hub Two who's design is well past its best before date.
If you do decide to get a different router, consider what you'd need after your next upgrade, for example if you are on FTTC now then get a router that is also capable of handling higher speed FTTP when it becomes available, or perhaps a built in phone socket that allows you to have a VoIP landline phone, or traffic quality of service controls to make browsing more responsive, better WiFI standards, etc, etc ...
MrDonaghey
Re: Router Faulty
Thank for the advice I think I'll just get one from Argos tonight. I'm not a heavy user so I'll something mid-level.
I've Found the help guide so I should be set
https://www.plus.net/help/broadband/broadband-connection-settings/
Fixes: 146
Re: Router Faulty
@MrDonaghey
Just a note, if you currently use a DSL cable (NOT WAN) on the Hub you will need a modem/router.
For a router only device for Full Fibre (using WAN port) follow the instructions for "If your fibre router is connected to a BT Openreach modem"
mystreet1
Seasoned Pro
Fixes: 7
Re: Router Faulty
@MrDonaghey
Try one of these
https://uk.webuy.com/product-detail?id=4023125028458&categoryName=WIRELESS-ROUTERS&superCatN...
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
spile
Re: Router Faulty
I am wondering why you didn’t call Plusnet and ask them to send you a replacement router?
MrDonaghey
Re: Router Faulty
It was early Sunday evening, and I thought the offices would be closed, so I was hoping for an e-mail or something to contact.
Thanks for all the help Smiley
doas
Re: Router Faulty
What would you recommend as a better more secure router than the hub 2? Explanations and prices please.
Tags (2)
spile
Re: Router Faulty
Better would depend on what you are trying to achieve and for what purpose. Put another way, what functionality do you need that the Smart Hub 2 does not have?
More secure? https://community.plus.net/t5/My-Router/How-secure-are-the-Hub-2-routers-and-ways-to-keep-them-secur...
