Router Died - Cant connect othet Plusnet Routet
TheGwilliams
Home from work and zero power to existing fibre router.
Have another plusnet router at my workplace so brought it home as a fix until I can arrange a longer term replacement.
Following the help guides to connect it but getting nowhere.
For the sake of my sanity and mental wellbeing (I have 3 children who need Internet access more than oxygen) can someone please help me get it connected 😬
5 REPLIES 5
Mustrum
Fixes: 81
Re: Router Died - Cant connect othet Plusnet Routet
What old roter, what is the dead one?
TheGwilliams
Not sure on the model at home but both supplied by plusnet.....
Work router is a sagemcom ....
TheGwilliams
Update.... work router isn't fibre. Home is.
Won't be able to get it to work.
Disaster.
Fixes: 480
@TheGwilliams
Is the hub less than 12 months old so still in guarantee?
If not, when did you last take out a new contract? If it was recently or you are getting near the end of one try ringing the Customer Options Team on 0800 013 2632 and ask if there's a way such as starting a new contract that will enable them to send you a new one for the P&P charge.
Let us know how you get on.
Fixes: 1,665
I'm really sorry to see your router had stopped working.
From what I can see you've since rang us and we're sending you a new router.
Can you let me know if you're still having issues once you've got it?
