New Hub Two and some questions
- My Router
- New Hub Two and some questions
23-08-2022 6:14 PM
I received my new Hub Two today and I have a few questions if I may.
- I have a WD MyCloud NAS drive with a private static IP address set up in the NAS drive's dashboard. I see this has transferred into the hub with the same IP but I want to check that an IP address of 192.168.1.40 falls within the static IP range still. I believe it had to be below 192.168.1.64 on the Hub One.
- Secondly, I notice within the Firewall settings that the NAS drive gets a mention under port forwarding. I didn't set this up so I was wondering how it got there and whether it should be there and how I'd know if the settings were correct.
- I appear to have a connected device under an IP address of 192.168.1.102 but it says it's been assigned as a static IP address. I have no idea what this device is as it's called "unknown_MAC_Addess" where MAC address is an actual MAC address. I can't seem to identify this device and I'm unable to Remove it as the Remove button is greyed out. What can/should I do? Any ideas anyone.
- I have a Sky Q box and a Sky Mini box. The boxes's don't seem to be listed under devices. Are they usually hidden for some reason? They seem to be working with the new hub.
- Each device seems to have 'Yes' beside 'Always use this IP address' even when they are using DHCP. Is this the preferred option and why?
Thank you for any assistance.
Annie
Annie
Message 1 of 1
(1,287 Views)
- My Router
