Reserved IP Address
Re: Reserved IP Address
The Hub two does what is asked of it and is intended for the mainly non technical user. You are given the option to use your own device is you so wish.
Like most irritations I try to ignore them
corringham
Seasoned Champion
Fixes: 23
@scubamad, on the topic of a possible future Gigaclear connection, I would point out that you can use your own router with Gigaclear (any router that has a WAN port should work - no configuration is required as the ONT will simply allocate the router an address). So if you decide to buy a competent router, just make sure it can cope with the Gb speeds available with Gigaclear. The Gigigaclear supplied router is OKish, but I prefer to use my own.
