Problems with Hub 2
outcast
Aspiring Champion
Fixes: 19
Re: Problems with Hub 2
@jab1 wrote:
... I just find it strange that Redhill seems so badly served ...
I've been doing a lot of checking, and a large surrounding area ONLY has Openreach ADSL
Checking the mobile networks, there is barely any indoor data coverage on all four networks, O2 or Vodafone most hopeful.
I also check all the fixed access wireless broadband providers, and none of them cover Redhill !.
As far as I can tell, only the four providers I listed can offer anything better than ADSL as shown on the map.
outcast
Aspiring Champion
Fixes: 19
@tudorradulescu  - are you "out of contract" with Plusnet ?, and if not how many months do you have remaining ?
Fixes: 391
Fair enough - but that makes me wonder why a reasonably affluent area is so badly served - by BT or altnets. I'm amazed the residents haven't kicked up an almighty stink.
outcast
Aspiring Champion
Fixes: 19
They will when their landline PSTN phones get cut off at the end of the year, and find "Digital Voice" is hopeless over ADSL !
Getting further away from the telephone exchange area, Openreach FTTP seems to be more available, but that doesn't help @tudorradulescu
outcast
Aspiring Champion
Fixes: 19
@tudorradulescu wrote:
I am within the purple dots zone according to the map,
So if I remove the red dots (representing Virgin), this map is clearer -
(again the telephone exchange is indicated by the blue tear drop)
The darker purple dots around the High Street are Hyperoptic, and the lighter dots are Hey! and F&W
Screenshot 2025-02-11 at 19-51-42 Browse Maps and Check Broadband Performance and Coverage Across the UK.png
Fixes: 391
Just out of interest, I remembered I had an oldish (December 2023) OpenReach FTTP build diary - just checked, and says: 'we are building in this exchange now' - so, unless something has gone seriously wrong, FTTP from OR should be available in at least some of the town.
outcast
Aspiring Champion
Fixes: 19
Yes away from the telephone exchange area FTTP does seem available,
but that doesn't help @tudorradulescu  who confirmed in Reply #16  that they can't get Openreach WBC FTTP
so for this topic, AltNets are the only hope ?
Fixes: 391
That is true, but I would have thought they would still cover the whole area within a reasonable timescale. After all, as I have said, Redhill is reasonably affluent, and I imagine businesses trying to work on (apparently) slow ADSL aren't that happy. I know they have a bit of a 'we don't like modern development' council, but if the residents kick up enough of stink....
outcast
Aspiring Champion
Fixes: 19
... out of all providers you kindly listed only Link Broadbands has come back with a positive result
I'm not sure what you're looking at given that the choices were ... [Virgin, Hey!, F&W, Hyperoptic]
Never mind, I've worked out how you got to that !
However -
On Link Broadbands I get 3 options that show up:
- FTTP superfast fibre 80mbps down / 20 mbps up
By guessing a nearby street address postcode and seeing what's available gives the results shown below.
You can see that (in this example) Link are offering BOTH AltNet FTTP, and Openreach FTTP.
The AltNet's FTTP lowest speed tier is 100/100Mbps,  whereas Openreach's FTTP is 80/20Mbps .
So what YOUR results said is available is Openreach FTTP - which you've previously posted is unavailable !.
@tudorradulescu -
I think you need to contact Link or F&W and confirm whether they can install (either) FTTP at your address.
If they confirm Openreach FTTP is available, then you could chase Plusnet to verify that the Openreach database is correct for your address (and upgrade with Plusnet), otherwise try signing up with Link or F&W and see whether installation completes.
