Printer not accepting password/key
Fixes: 251
Re: Printer not accepting password/key
Hub 1 to Hub 2 change, old printer - I’d be looking at a/b/g mode compatibility. Would need to check the printers wifi spec.  Try changing the mode.  Also check the printers WAP support - by default the Hub2 uses WAP2.
Pete11
Seasoned Pro
Fixes: 4
I had run out of patience (and temper), but the issue seems to be solved/fixed. I did a clean install of the drivers and YESSS, printer is working. It seemed to be either a port problem or was looking for a wired connection which I don't have.
Thanks to all who gave advice/help/solutions, now I'll go and count how many more grey hairs I've got.
Thanks all.
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
Fixes: 251
That solution is confusing.  Do not see how updating the printer driver on the PC altered the printer’s ability to connect to the hub properly.
None the less, this being fixed for you is good .
Pete11
Seasoned Pro
Fixes: 4
I can't understand it either, but, the clean install seems to have done the job.
