Mesh Network
rooky
Mesh Network
What Mesh Network are folks using pls
I been looking at a Netgear 370 twin pack or a 770 twin pack anyone got any experience with them please or any suggestions.
6 REPLIES 6
DerekW
Re: Mesh Network
Would be helpful if you could tell us your use case scenario, type of building you live in, devices etc.
Once you provide this information some of the more knowledgeable people will be able to offer some guidance.
Me personally, I use a TP-Link Deco set up
"No one has ever become poor by giving" - Anne Frank
rooky
Re: Mesh Network
Well the house is only a 2 bedroom new build house built with stone and block so quite dense in construction.  I want to be able to get a nice speed internet all around the house and garden.
Is TP Link good which one you suggest please
there about 35 devices connected to current router
Fixes: 118
Re: Mesh Network
@rooky
Any chance of running ethernet cable? Gives a good solid starting point and is future proof. It can be run externally if this is a better option than disruption indoors.
Once run, all you need are Wireless Access Points (WAP)
corringham
Seasoned Champion
Fixes: 23
Re: Mesh Network
I use Ubiquiti kit - very reliable, seamless moving from AP to AP, and nice central management system. It is mainly aimed at business use, but I think it is is actually easier to manage than many consumer products, while still having potential to set up VLANS, multiple SSIDs, guest portals etc.
They have a range of indoor and outdoor APs, some offering long range coverage, which are ideal for large gardens. I cover several buildings and >2 acres with 5 APs.  I often have > 100 devices connected without anything getting stressed.
rooky
Re: Mesh Network
Hi can you please suggest a starting point. Posible router a d 1 indoor and 1 outdoor access point. Do they need power?
Where from pls
corringham
Seasoned Champion
Fixes: 23
Re: Mesh Network
I tend to use broadbandbuyer as they are always reliable, and they have a lot of choice - too many in some respects as it is hard to pick the best for a particular use.
I'd suggest looking at something like https://www.broadbandbuyer.com/products/51082-ubiquiti-ucg-ultra/  and https://www.broadbandbuyer.com/products/50614-ubiquiti-uk-ultra/
The APs are PoE, so you would probably need a unifi PoE switch too or injectors - if powered from a switch they will have an ethernet connection, but if used with an injector they can be used as mesh devices.
Have a browse through the options and read some reviews - then mull it all over for a while. The options are boggling.
Edit: I've just realised you probably have a router, so you'd only need the APs, but they ideally need a controller which can be a router or a separate device, or software running on a PC.
