Port forwarding on hub 2
- My Router
- Re: Port forwarding on hub 2
20-04-2025 10:36 PM
I'm trying to find a way to port forward my android tv box on my plusnet hub 2 router but I'm having trouble finding out how to do it. If anyone can help me, please message me please.
Message 1 of 3
(1,212 Views)
2 REPLIES 2
21-04-2025 7:07 AM
Moderators Note
This topic has been moved from Broadband to My Router
Message 2 of 3
(1,164 Views)
21-04-2025 7:12 AM
First question might be, why and what port do you need to forward to your TV box?
First set the TV box to always use the same IP address - navigate to http://192.168.1.254/my_network.htm (you'll need your admin passwod) and find the device, Click on it and click "Always use this IP address:" so it shows as yes.
Then to create a port forwarding rule navigate to http://192.168.1.254/firewall.htm
Fill in the ports etc you want forwarding and select the device you want to go to and then click the + symbol.
Click save changes and the rule is now created.
- My Router
