Hub 2, how to change the router’s admin panel port?
Rageypeep
Hello, I have just turned an old phone into a small web server, works great, have it running on port 8080 fine. However, I want to more it to the default incomming port which is port 80, however the admin pannel is located on that port and I want to more it to port 8081, however I cannot seem to find an option to change it, past roters I have had let you do this, am I going blind or something?
4 REPLIES 4
Re: Hub 2, how to change the router’s admin panel port?
@Rageypeep
Were those previous routers that enabled you to do this ISP supplied or did you buy them yourself?
Do you still have any of them?
Have you tried replacing the Plusnet Hub with one of those routers?
Rageypeep
Iv'e always been with Virgin Media, there router let you do it, I don't have it anymore because you have to send it back to them. Also its for a cable not fiber, so it used a diffrent connection.
@Rageypeep
How are you connecting to the admin page? Locally or from a remote site?
However, I want to more it to the default incoming port which is port 80, (assume you mean move?)
Why do you need to do this?
Fixes: 1,495
You can forward port 80 in the firewall rules, you don't need to change the hub admin page port which doesn't broadcast to the outside world anyway.
