Port Forwarding Hub2 - Lost Noob
flat155marest
I'm trying to play a game (City Skylines) with a multiplayer mod that requires both parties access the same server (my terminology might be wrong).
Following a tutorial.
Hub2 Created a Port Forwarding Rule
Name + My internal Computer IP + Start 8000 End 8001 (Internal and External) TCP/UDP
Checking on openportcheck for 8000 does not connect. It auto fills my external IP and I cannot edit the box
Downloaded 'No-Ip' and set up a Host pointing to My external IP
Read a troubleshoot on here who talked about 'DDNS' so I went into Dynamic DNS and set up my details from No-IP
I tried 'Host' only and Host:8000 and neither shows in the portal check tool.
Now I'm completely lost.
Any suggestions?
4 REPLIES 4
Fixes: 128
Re: Port Forwarding Hub2 - Lost Noob
For a port forward rule to be checked using an open port checker the application using the port forwarding rule must be running. In the case City Skylines
The port checker does use your external IP address, example https://www.canyouseeme.org/ and it's greyed out with this one.
If you check the Advanced Settings >Technical Log >Event Log >Category "FRWL" do you see any connections attempts, something like
FWL Port Forward Server(Internal IP) TCP 8000 accepted a new connection from (IP Address of the connecting device)
when you use the port checker or use the game?
flat155marest
Hi Dan
Thanks for replying. I've started a session in City Skylines and I think it's correctly set up.
I've checked the log for FRWL and it reports:
FWL Port Forward Server(192.168.1.188) TCP 8000 accepted a new connection from 158.247.7.200
When i check the portchecking website it still doesn't detect the port
Fixes: 128
If there is just one line with that connection message then I'd say it is connected.
IP Address 158.247.7.200 resolves to www.noip.com
HTH
flat155marest
OK Dan thanks for your help. I'll see if we can get it running!
