Pod-Point EV charger unable to connect to WiFi
cdrnet
Hello everyone,
I have a Pod Point EV charger that needs to connect by WiFi to my new PlusNet Router. It worked just fine with my TalkTalk router so it must be possible.
It has a fixed IP address of 192.168.1.1 and I am able to login to it and browse to my router SSID and enter the passcode. There are no errors at the Pod Point end so I was wondering where on the router I can enter the IP address and allow the device to get online?
Any help will be gratefully appreciated.
Thanks,
ANDREW
3 REPLIES 3
Gel
Champion
Fixes: 29
Re: Pod-Point EV charger unable to connect to WiFi
Fixes: 383
Sorted elsewhere., @Gel 😀
cdrnet
Thanks for the suggestion. That was certainly the line I was expecting to be the source of the problem.
It turned out to be the device taking a new DHCP and displaying as a Gaming Controller (of which he have several on our network).
I wouldn't have got there on my own as I could no longers ee the wood for the trees.
Have now labelled it clearly and all seems hunky dorey.
