Plusnet fibre with ax3000
Jonny_doe
Hello just got plusnet fibre 74 , with the hub 2 , but wifi isn't much good , so I got a tp-link ax3000 router ..
I put the hub 2 into bridging mode
And plug a patch lead into wan both router and hub 2 ..
On the tp-link , I put the connection to pppoe and set "my [email protected] and my password to get into my account , but the router won't connect to the Internet...
What am I doing wrong ?Huh
2 REPLIES 2
Re: Plusnet fibre with ax3000
@Jonny_doe welcome to the community
You need to connect to one of the LAN ports on the Hub Two NOT the WAN port
HTH
Edit: I am assuming this a copper connection, if you are Full Fibre then you do not need the Hub two you connect the AX3000 WAN port to the ONT.
Jonny_doe
Yes the plugged into LAN worked , thanks for your help 👍
