Plusnet Modem
Fixes: 145
Re: Plusnet Modem
@jab1
I would image @Boz during his adventure through the Hub One menus he came across UPnP along with Port Clamping, both are found in the 'Firewall' section. By default UPnP is enabled.
@Boz the internet disconnect can by found from the home page by navigating to Advanced Settings (continue to advanced settings) >Broadband >Internet
Advanced Settings >Home Network >DHCP Table will list all devices that have recently sucessefully connected to your Hub One.
If you have any question regarding the Hub One post here and I'll do my best to help
Dan.
Fixes: 378
Re: Plusnet Modem
@Dan_the_Van Cheers. I only have a couple of screenshots of the Hub1, which are usually enough for me to guide users if I need them to give me details from their unit, and never had want or need to delve further. If I do need any help, I know you will be my guide. Smiley
Boz
Re: Plusnet Modem
I've found the "disconnect" button!!  My thanks to Dan and John.
Boz
Mav
Fixes: 518
Re: Plusnet Modem
Moderator's note(s):
Thread moved from Fibre Broadband to My Router.
Forum Moderator and Customer
