Plusnet Hub One (standalone wi-fi only)
- My Router
- Plusnet Hub One (standalone wi-fi only)
30-06-2017 9:02 AM
Can anyone suggest to help me how to set up Plusnet Hub One as standalone wifi only as I want to use my Billion Router act as a VDSL Modem but using Plusnet Hub One as a Wireless only. Can it do this way?
Re: Plusnet Hub One (standalone wi-fi only)
30-06-2017 11:23 AM
Hub One is a VDSL/ADSL modem/router.
30-06-2017 11:32 AM
Because Billion VDSL Router as VDSL is excellent broadcom chipset plus full stats on the line can see more about DLM on the line which Hub One only limit it. That's why I want to keep Billion as the VDSL modem only and use Hub One for wireless only because Billion wireless isn't very good (only support 2.4G).
Billion full stats is better see below:
adsl info --stats
adsl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 29081 Kbps, Downstream rate = 86377 Kbps
Bearer: 0, Upstream rate = 19999 Kbps, Downstream rate = 80000 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 7.3 15.9
Attn(dB): 11.7 0.0
Pwr(dBm): 12.4 -0.3
VDSL2 framing
Bearer 0
MSGc: -6 26
B: 203 237
M: 1 1
T: 0 42
R: 10 16
S: 0.0809 0.3781
L: 21153 5374
😧 8 1
I: 214 127
N: 214 254
Q: 8 0
V: 5 0
RxQueue: 78 0
TxQueue: 26 0
G.INP Framing: 18 0
G.INP lookback: 26 0
RRC bits: 0 24
Bearer 1
MSGc: 186 -6
B: 0 0
M: 2 0
T: 2 0
R: 16 0
S: 5.3333 0.0000
L: 48 0
😧 3 0
I: 32 0
N: 32 0
Q: 0 0
V: 0 0
RxQueue: 0 0
TxQueue: 0 0
G.INP Framing: 0 0
G.INP lookback: 0 0
RRC bits: 0 0
Counters
Bearer 0
OHF: 0 639894
OHFErr: 0 1144
RS: 1433876000 355707
RSCorr: 50506 7108
RSUnCorr: 0 0
Bearer 1
OHF: 94147112 0
OHFErr: 0 0
RS: 1129764607 0
RSCorr: 700 0
RSUnCorr: 0 0
Retransmit Counters
rtx_tx: 29135 0
rtx_c: 5579 0
rtx_uc: 0 0
G.INP Counters
LEFTRS: 22 0
minEFTR: 79983 0
errFreeBits: 1844929916 0
Bearer 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 722772634 0
Data Cells: 1543458409 0
Drop Cells: 0
Bit Errors: 0 0
Bearer 1
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 0 0
Data Cells: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 0 912
SES: 0 0
UAS: 27 27
AS: 1512489
Bearer 0
INP: 49.00 0.00
INPRein: 0.00 0.00
delay: 0 0
PER: 0.00 3.98
OR: 0.01 64.22
AgR: 80344.32 20063.54
Bearer 1
INP: 4.00 0.00
INPRein: 4.00 0.00
delay: 3 0
PER: 16.06 0.01
OR: 95.62 0.01
AgR: 95.62 0.01
Bitswap: 5850/5850 175/175
Total time = 17 days 12 hours 8 min 36 sec
FEC: 50506 7108
CRC: 0 1144
ES: 0 912
SES: 0 0
UAS: 27 27
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 15 minutes time = 8 min 36 sec
FEC: 15 0
CRC: 0 1
ES: 0 1
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 4 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 12 hours 8 min 36 sec
FEC: 1009 280
CRC: 0 26
ES: 0 21
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 1 day time = 24 hours 0 sec
FEC: 3205 392
CRC: 0 66
ES: 0 53
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 17 days 12 hours 8 min 9 sec
FEC: 50506 7108
CRC: 0 1144
ES: 0 912
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
HELLO Billion BiPAC 8800NL
adsl info --pbParams
Status: Showtime
Discovery Phase (Initial) Band Plan
US: (7,32) (871,1205) (1972,2782)
DS: (33,859) (1216,1961) (2793,3970)
Medley Phase (Final) Band Plan
VDSL Port Details Upstream Downstream
Attainable Net Data Rate: 29081 kbps 86377 kbps
Actual Aggregate Tx Power: - 0.3 dBm 12.4 dBm
VDSL Band Status U0 U1 U2 U3 U4 D1 D2 D3
Line Attenuation(dB): 2.5 13.5 20.4 N/A N/A 7.0 16.0 26.1
Signal Attenuation(dB): 2.5 12.8 19.7 N/A N/A 9.1 15.9 26.1
SNR Margin(dB): 15.6 17.3 15.3 N/A N/A 7.4 7.3 7.3
TX Power(dBm): -14.4 -29.6 -0.5 N/A N/A 8.0 7.9 7.0
30-06-2017 11:40 AM
Just connect the Wan port on the Hub one to a Lan port on the other router, you may need to change address range one one of the routers. I presume you don't need to be able to see anything on the Lan ports of the Billion from wifi connections?
30-06-2017 11:52 AM
Have a look here on how to set up the Hub One as an access point.
- My Router
