Plusnet Hub 2 change access port.
- My Router
- Plusnet Hub 2 change access port.
11-03-2023 4:10 PM
I want to hide my router on the LAN. Is there any way to change the access port from 80 (192.168.1.245:80) to something less obvious?
Message 1 of 2
(891 Views)
1 REPLY 1
Re: Plusnet Hub 2 change access port.
11-03-2023 5:14 PM - edited 11-03-2023 5:15 PM
With a Hub One or Two is is not possible to change the listening port from 80, if it's important to you then I'd suggest a third party modem/router.
HTH
Message 2 of 2
(868 Views)
- My Router
