PPPOE authentication with Plusnet FTTP not working
witherford
Re: PPPOE authentication with Plusnet FTTP not working
Can you share the "setup" details please and I will try them?
witherford
willcutforth
Fixes: 113
Yeah they are, or they can be found on https://www.plus.net/help/broadband/broadband-connection-settings/
 Will Cutforth
bobpullen
Fixes: 330
@witherford wrote:
2) The network I connect to on the ISP side is likely to be very different, I reckon and an entirely separate network in ways, I reckon if I went back to the copper network I would likely be connecting to a different access concentrator.
On the contrary, you authenticate against the same platforms regardless of VDSL/FTTP.
@MisterW wrote:
@bobpullen is there any mileage in trying the 'setup' username? would that confirm if it is a basic authentication problem.
The setup username isn't appropriate, however I will share some authentication details privately with @witherford that bypass the L2TP tunnel to the BNGs. As above though, the current path is near (if not) identical to the VDSL service, so logically I would not expect any difference.
@witherford wrote:
... so the golden question is, who has access to the access concentrator mentioned previously in this thread and can this be passed onto them.
I believe checking the logs on there is the next logical step
I'm afraid this is probably where we draw the line in terms of diagnosis from this side. We're talking core equiment of a multi-ISP platform. Whilst I can't explain your experiences with old vs. new services, this is an example of a single subscriber struggling to connect third party equipment, where the ISP-provided device (and I assume others) are working fine. Might sound a bit harsh (sorry if so), but we've not got much collateral to be ruffling certain feathers Wink
Edit: @MisterW - I thought you were referring to the default router username for some reason. There may be some merit in trying the Wholesale test creds, definitely no harm in trying.
Fixes: 585
That's the strange thing, AIUI they aren't any different, once they get into the guts of the Openreach/BTw system. Both FTTC and FTTP are GEA ( Generic ethernet access ). I cant imagine that the concentrators would be different.
Can you share the "setup" details please and I will try them? If Bob thinks it might give useful information then I can
Having said that , the [email protected] is worth a try. I'm not sure about the bt_test@startup_domain though
edit: Bob's post crossed with mine and hopefully provides better ideas
witherford
The details sent to me privately do not work, I have tested the below details and have detailed the outcome.
Testing access to BT's network:
Username: bt_test@startup_domain
Password: test
Outcome: Uses the same ACC and fails
Testing access to the plusnet network:
Username: [email protected]
Password: test
Outcome: does not work
So it looks like my prediction mentioned before was correct it's not getting into the Plusnet network, according to the diagram linked below the login details i used above tests BT's network. Well when I was looking at the logs the ACC that it was trying was the same one, acc-aln2.nao.
Broadband Faults Guide - Authentication (Auth) - Plusnet Community
So it looks like acc-aln2.nao is BT's not Plusnet's and that is where this is failing for some reason.
Fixes: 585
but I dont see why the Hub 2 would be getting a different concentrator ? if it is ?
does the Hub 2 event log show which concentrator its hitting for its PPPoE auth ? (probably not!)
witherford
Good call, just checked and it does not, I would have to get a hub and plug both the Plusnet router and ONT into the hub and perform a packet capture for any hope of getting that I think.
witherford
I think it's going through the same concentrator so either the Palo alto is doing something odd with the PPPOE requests or the concentrator is denying me access.
Fixes: 585
You would, I've got a 5 port managed gigabit switch that can do port mirroring for just that situation.
I'd be pretty sure its the same concentrator. I cant see why (or how)  it would , but if it was denying access, I wouldnt expect it to even send a CHAP authenticate request. The PA doing something odd is my favorite Im afraid.
Did you manage to find the Cisco ?
witherford
I think the cisco router is for weekend me, I might log a call with Palo Alto as I do have support with them.
Fixes: 585
One last straw to clutch ( for the moment!) can you try setting the authentication to auto ( rather than CHAP ) in the advanced PPPoE settings
witherford
Already tried long before coming here
witherford
Which make and model is the 5 port switch?
Fixes: 585
Its a Netgear GS305E https://www.netgear.com/support/product/gs305e.aspx#docs
I needed a 5 port switch a while ago and decided it was worth paying a little extra for a managed one. Just in case I needed the extra functionality, ( I havent yet used it in anger )
