PN Hub one Port forwarding help required
paulgul
I'm trying to set up port forwarding for a pi showing on my hub as piaware.
Referring to attachment Hub-1 it shows piaware as being on ip address 192.168.1.79 (this is the correct address ) but when I set up port forwarding and select device piaware it show ip address 192.168.1.76 (see attachment Hub-2)
How can I correct this - the device is on and operating ok but the port forwarding isn't working
Paul
2 REPLIES 2
Aspiring Hero
Fixes: 75
Re: PN Hub one Port forwarding help required
Hi @paulgul
A power off the modem/router might clear the IP address confusion as I have had the same issue recently with IP address showing up incorrect .99 when it should have been .250
Edit
I have a Hub One and assign hostname to each port forward rule rather than an IP address.MAC address does not appear on my device.
Dan.
paulgul
Thanks Dan,
Yes, that has cured the problem - port forwarding working now
Paul
